Buckling Analysis
Buckling Analysis
I created a simply tube made up of plate elements and ran two buckling cases:
1. One end is fixed
2. One end is pinned
Now according to Eulers simple equation for linear buckling, the effetive length changes with the type of constraint. In Nastran, both cases yield the same eigenvalue. Am I doing something wrong? Does Nastran account for the type of constraint like the theoretical formula?
Brian
1. One end is fixed
Brian
RE: Buckling Analysis
Using equation (4) in SP-8007 you have the critical stress. I would use this and then
Sigma-x = axial stress
E = Young’s Modulus
nu = poisson’s ratio
t = thickness
r = radius
to get the total buckling load, just multiply by area (2*pi*r*t).
When you run an FEA linear buckling analysis, the lowest "positive" mode (eigenvalue) times the total applied load is the buckling load. Multiple this by your knock down and you have the max allowable load for the structure. Knock down factors are more critical in cylindrical shell buckling than for other types of structures. SP-8007 should cover this.
