Online salinity measurement in oil/gas pipeline
I have been searching for a sensor that would be permanently installed online on a pipeline to measurement the salinity level of an oil/gas well. Does anyone know of such a device?
RE: Online salinity measurement in oil/gas pipeline
http://www.roxar.com/files/Brochure_RFMWCM_all.pdf
Its the 2. model mentined in the brochure (p3-4)
Best regards
Morten
Best regards
Morten
Thank you for your hint but Roxar Water cut meter is not appropriate for the job. The salinity detection system is just an indicator and not a quantitatif measurement.
The "Autozero" program is design to correct for a change in oil density and not salinity.
This salinity measurement (if I manage to find an online system) would be fed into a Multiphase meter to correct flowrates.
did you try an autu-wash option with your refractometer?
