Nozzle close to tan line
Hello all,
I need to evaluate shell stresses at a nozzle attachment on a pressure vessel. PD5500 requires that the distance between the end of the cylinder and the edge of the attachment should be not less than r/2. Where 'r' is the radius of the shell.
In my case the nozzle is less than r/2 away from the tan line.
Can someone please recommend what to do? Is there an alternative calculation procedure that takes into account the stiffening effect of a 2:1 SE head.
FEA is not an option at this stage.
RE: Nozzle close to tan line
As codeeng pointed out, FEA is really the best tool. However, since you stated that that is not an option, the use of stress reduction (correction) factors is just about the only way to go. The values I've seen have also varied from 1 to a max (min?) of 0.4. In other words, if the nozzle is very close to a stiffening element then you'd calc the stresses as if the nozzle is distant from any discontinuities using whatever method you have available. Then you'd reduce that stress by a factor of as much as 0.4 depending on the actual proximity to the discontinuity.
One published source of stress reduction factors is API-650 in Appendix P3 figure P11. This figure was developed for tanks, but unless you find other sources it may be the only thing for you to go with.
On the positive side, the stiffening element will carry some of the load, so you can conservatively calculate the stresses as though the nozzle is in the middle of nowhere. If they are acceptable, you're done.
The negative side is that if you are using nozzle spring rates to calculate the piping loads, the presence of a stiffener will obviously reduce the flexibility of the nozzle thereby driving up the pipe loads.
jt
FEA is not an option,, but Saddle Pro. may be the best Engineering Tool's for this application and sloution. Saddle Pro. The Home of FE-Pipe www.Paulin.com
