Repair of Frost Heaved Sidewalk in Gravel
We have been asked to evaluate the cause (and possible repair) of a sidewalk that has been damaged by frost heave or frost jacking. The soil below the slab consists of alluvial gravel with sand and silt. Silt content is less than 10 percent. However, the water table is reported by the client (a municipality) to sometimes reach the surface. We had a very dry winter in Eastern Washington this season and consequently very little snow on the ground. This combined with the usual below freezing temperatures and a high water table I believe caused the jacking of the sidewalk. Assuming these are the likely causes, we recommended drainage, combined with removal and replacement to at least 18 inches with imported clean gravel. I am interested in hearing from those of you in cold weather regions on how you typically handle this type of problem. Thanks!
RE: Repair of Frost Heaved Sidewalk in Gravel
