SUBMODELING ISSUES
SUBMODELING ISSUES
I am having some doubts regarding SUBMODELING in Abaqus.
I am analysing a Beam with bolted joints, and I have defined two element sets and node sets in the global model and I am saving results for those. MY submodeling is driven by the global models, and I am having the same element set and node set, but my element numbers and node numbers in the submodel is different and also the coordinates, however the name of the element set and node set is same.
My question is does the node number have to be same ?
these are the commands I am using
*SUBMODEL,GLOBAL ELSET=elset_name
Node_set
*STATIC
*BOUNDARY,SUBMODEL,STEP=1
Node_set
I appreciate your responses
thanks
Srini
Node_set
*STATIC
Node_set
thanks
Srini
RE: SUBMODELING ISSUES
corus
thanks agian
Srini
