Bearing failures Electrical Motors
Hi All,
I´m looking for the typical bearing failures in Electrical Motors, when they´re being tested without load.
I´ve read they always shout be tested with a minimum load, if they´re being tested without the minimum load, what bearing failures will occur?
And is there a normalised acceptance test in the field available?
Thanks!!
Thanks!!
RE: Bearing failures Electrical Motors
