Working in Intralink workspace while offline
Is it possible to open and access files in an Intralink 3.3 workspace even though i am not connected to the database server? I have the correct licenses for ProWildfire and Intralink on my laptop. If i create the workspace when i am at work and check out the parts, can i open them in the workspace when i am out of the office? I get an error (not connected to database) when trying to log into Intralink so i don't get to see the workspaces at all. any help or hints would be great. thanks
RE: Working in Intralink workspace while offline
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Before you try and log into Intralink, there should be an option at the bottom to Launch Pro-Engineer (without logging in) This option expands to Launch into a local workspace.
We use this option to work locally in a workspace if there are no Intralink licenses available.
This would only work assuming you could pick up a Pro-e license locally (assuming no connection to database/license server).
Hope that helps!
Cadbhoy.
