liner for sulfur gas blower
First, thanks in advance for any help you can provide.
I am building a blower housing which will be handling sulfur gas.  The shaft for the fan is water sealed so there is potential for mild sulfuric acid.
The unit I am replacing seems to have a rubber liner.  Is this the best material to line the unit with?
If it is then where can I get a liquid rubber product that I can paint or spray on myself?
Housing and all parts are stainless steel.
RE: liner for sulfur gas blower
Am I posting this in the right area?
I didn't think i needed to reinvent the wheel on this, seems like it would be a pretty common setup.  Should this be in the chemical plant forum?
