Axle Flange Nuts
Axle Flange Nuts
Would anyone know of a good resource for getting dimensions and purchasing OEM type axle flange nuts such as those used for FWD and rear IRS applications? I'm looking for a relatively large flange diameter (52-55mm), something compatible with a 42mm inner diameter wheel bearing. Preferable the nut will have a built in feature to allow staking it to a slot cut into the treaded portion of the axle end (Hondas come to mind). Any suggestions would be greatly appreciated.
Joest
Joest
