File Exporting Macro
Good Morning
I am looking for a macro that will export an iges file into the current directory. I would like to create a button to execute this macro so I don't have to go into the file save as pull down all of the time.
Chris
Chris
RE: File Exporting Macro
Option Explicit
Dim swApp, Part As Object
Dim BoolStatus As Boolean
Dim LongStatus As Long
Dim e As Long
Dim w As Long
Dim Msg As String
Dim PartName, Rev As String
Sub main()
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
If ((Part Is Nothing) Or (Not (Part.GetType Eqv swDocPART))) Then
Msg = "A part document must be active to use this command!"
LongStatus = swApp.SendMsgToUser2(Msg, swMbWarning, swMbOk)
End
Else
PartName = Part.GetPathName
PartName = Left(PartName, Len(PartName) - 7) & ".igs"
BoolStatus = Part.SaveAs4(PartName, 0, 0, e, w)
If BoolStatus = False Then
Msg = "Failed to save IGS document!"
Else
Msg = "Saved part as " & PartName
End If
End If
Set Part = Nothing
Set swApp = Nothing
End Sub
Chris
If you look in the API help, there are a bunch of examples. They are listed alphabetically rather than topically, so sometimes it is hard to find a specific call, but there are a bunch there.
Evan T. Basalik, MCSD
It's all about prioritization...
