Not asking to find file anymore
Using SWX 2005 SP1.1
I have an assembly made up of about 10 parts.
I took those parts and moved them to other directories, but left the assembly where it was.
I have done this before and it used to, when I opened the file, say it couldn't find file, and then would ask me to find it. I would then redirect it to the new location.
Now it has not been asking and it just supresses them.
When I right click on the part name and select 'set to resolved', it thinks for a minute but then it just stays the same. It doesn't ask me to find the file that way either.
Is there something I am doing wrong?
RE: Not asking to find file anymore
In the future, use SWx Explorer to move files around. This way, they will not lose their references.
As MElam suggests, SW Explorer is the easier way, however it cannot move files, at least not in SW2004. It can only rename, replace & copy files. So basically it does what I explained above, but in a more user friendly GUI.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
I ended up rebooting and now it is working like it used to. Strange.
Thanks for the 'saveas' and opening the files first option. I will try those in the future.
I typically try to use Solidworks Explorer as much as possible, but I have been having problems with it since I switched to 2005. When I go to rename a file and hit the button 'find where used' it never finds anything even though I know there are things. Hence the opening the file and redirecting method.
I'm just not sure if it's the files I am working on, received from another company, or if it is a problem with SE.
