Exporting Unrendered images
We are using SolidWorks 2001 and we need to export a high-resolution image of the unrendered model as we see it on screen, is this possible?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Exporting Unrendered images
Shift-PrintScreen to do a screen capture and then paste the captured image into Paint or something. Edit it as needed and then save as a .JPG Do it in Photoshop and you can save it as a PDF.
Bring back the HP-15
www.hp15c.org
Surely there has to be a way of exporting an unrendered image???
Also you could use pdf995 from http://site4.pdf995.com/download.html
Either way, for best results, set your screen resolution to as high as possible before creating the screen capture or pdf.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
It has an easy-to-use dialog box, and if you scrounge around on that site, you might find something else you like.
Flores
What Image software do you use? If you are using MS paint then you need something better then that. I suggest Paint shop pro do scale your images up in size from the screen shots. I'm not sure but I don't think SW01+ did save as Jpg file and even if it did it wouldn't be any bigger then the screen shot. So you will have to scale it. That's why getting good image software is important.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
