difreence between earth fault an short circuit level
what is the difrence between short circut level and earth fault in electrical system, i can calculate SC level in a system,but how can i calculate erath fualt level??
regards ,
regards ,
RE: difreence between earth fault an short circuit level
Bung
Life is non-linear...
yes,in my case an impedance exist. but what is the advantage of using this ampedance ?
and you mean for reaching to 450A i should 31.5KA/R ???
If this is a real system, perhaps you should consult a licensed engineer to perform this analysis correctly.
