mtsubishi v6 balancing
i was wondering if anyone knows what the factory percent of the bob weight is on a mitsubishi 3000gt vr4 engine(twin turbo)
the machine shop is asking for this info so they can balance the crank corectly due to that i have much lighter pistons going in the engine.
any type of help is appreciated, or if anyone knows where i can get this info from.
thnks joe
thnks joe
RE: mtsubishi v6 balancing
i know that i can get a number as you said but i need to know what %of that weight actually is needed like chevy v8 take 50%, buick v6 are 35% i think, i need to find out what does mitsubishi require.
tnx.
If it is other than an even firing 6 then you have to go through the balance equation for the whole engine.
I would not go by what american manufacturers do. You might end up with a V8 chopped down to a V6 balance factor and it will run like a dodge.
Tell us a little more about this engine. Is it a 60 degree V6? Does it have three crank throws(shared crankpin) or six crank throws(one crankpin per cylibder)?
