Boundary conditions
Boundary conditions
I have a question regarding the boundary condition for a plate which is simply supported on all four edges. How do i simulate this condition in a FE software. what i mean is what are the d.o.f that i would have to constrain considering each node has 6 d.o.f..Thanks.
RE: Boundary conditions
Garland E. Borowski, PE
As the edges are simply supported no rotational restraints are required.
If you fix all the edges in xyz direction then membrane stresses will be induced which I assume you dont want as you said its simply supported.
Personally, I would only fix one point in xy direction and one other point in x direction.
In large dispacement analysis I think that the edges will try to move towards the centre of the plate, this distance will be greater at the middle of the edges (than at the corners).
Tx=0 (one point)
Tx=0 and Ty=0 (the other point)
You will see that loads in these SPC's are negligible, so your results will be reliable.
you are right. One of the replies had restrained on all 4 edges and I did not think about over restraining the edge 4 if you remove extra restrains from the other 3 edges. I guess I was thinking about beam theory not plate.
Thank You
Does it agree well with the test data?
Cheers
Greg Locock
