Sheet metal hole knock-outs
Hello all,
I am looking for some ideas on how to represent hole knock-outs (holes not cut all the way around) on sheet metal flat patterns. We use the flat pattern to create DXF files which are used as input to our lazer cutters so we need the knock-outs to be saved on the flat pattern.
Thanks.
RE: Sheet metal hole knock-outs
Laser cut (with connecting tabs) or partially punched (like electrical box)?
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Laser cut - with connecting tabs
If you create a knock-out like it would be made, with the connecting tabs, then it will show up in the dxf of the flat-pattern.
I think I have seen knock-outs online that can be downloaded. Do a search.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
I've created Forming Tools for these in the past (last company) just for representation.  If you do sheet metal in-house you can go the laser-cut route.  If these parts are going out to vendors, you really don't want to define the manufacturing process, unless laser cutting is a quality requirement of the part.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
cowman ... Are you using the Sheet Metal module? If you are, then, as Trogdor0 stated, the semi-circular slits which create the knock-out feature, will automatically be included in the flat pattern & DXF files.
The way we made a knock-out in our old cad package was to create two single lines ("C" shaped)with a gap between them. The laser would then make a single pass over these lines creating the knock-out. I assume when you say to just create the knock-out I will need to offset the "C" shape a small distance and make a closed shape for the knock-out.
You should create a couple of basic Pallet Features for this.  We created small single tab knockouts that we use for .437 - .625 knockouts, two tab knockouts for .625-1.00 and a four tab for knocouts over 1".  Then we just click Tools - Feature Pallet and add the appropriate type of knocout and adjust the diameter.
