Regulating valve with integrated check valve
I´m looking for the above valve, should be stainless, female 1/2" thread? The reason for the built in is that we have limited space?
Regards, Tommy
RE: Regulating valve with integrated check valve
GAS OR LIQUID...PRESSURE OR FLOW...BSP,NPT,SAE?
10 Bar working pressure,
Liquid.
BSP
I'm going to take some guesses...
I assume it's a flow control that you need...
and I assume that you are in the U.K somewhere...
If my assumptions are correct...you will find the part you require at ISIS Fluid Control...part number 204052.
This part number is for a 1/2" BSP 316 stainless steel flow control valve with integrated check valve. The working pressure is 400 BAR...but I don't think 10 BAR will be a problem.
If my assumptions are wrong and you do need a pressure relief valve with a check valve...you will have to build one...if you are not in the U.K...?????
Hydromech
