pour point and molecular weight of crude oil!
Hello to all,
I need to use equations to calculate the pour point and molecular weight for crude oil if have idea please help me?
thanks
RE: pour point and molecular weight of crude oil!
Your question needs clarifying, do you mean predicting product properties based on lab crude assays ?
hi 25362,
infact I have sp.gravity and viscosity of crude oil and I need to use equations if it is possible to predict the pour point and molecular weight and make comparison between the two results. I hope my question is clear.
thanks
I don't know of any valid algorithm to predict the pour or cloud point of petroleum oils as caused mainly by normal or slightly branched isoparaffins in the C20-C42 range, by using only gravity and viscosity.
For the relative molecular mass (molecular weight) one probably can get help from ASTM D2502-04. To characterize the crude, whether paraffinic or otherwise, one may use the VGC, viscosity-gravity constant.
For additional guidance you may visit some Google sites such as:
www.castdiv.org/archive/OnlineDataProcessing.pdf
www.epa.gov/chemrtk/crdoilct/c14858tp.pdf
