Periodic oscilation in power consumption of a reciprocating compressor
What could be the reason of a periodic consumption(we see an armonic wave of the intensity, amperes) of an electric motor coupled to a reciprocating compressor of 4 cylinders?
Could it be an error in the calculated inertial wheel?
thank you so much, any contribution will be appreciated.
RE: Periodic oscilation in power consumption of a reciprocating compressor
HVAC68
A larger flywheel will help to smooth out the the surges but there will still be surges since there must be a speed change for a flywheel to work.
How constant do you want the current to be and why?
Barry1961
on the other hand, the oscillation is of about 30% of a constant intensity, that I don't know if it's acceptable or not.
Thank you so much for your help!
Marc
Barry1961
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
