Trigger not working with Join?
Here is my trigger and it works great, However, I want to join a table called dbo.CustomerAddressBase and grab the accountbase.accountnumber and insert it into the table customeraddress.CFSMASCustNum, can I do this with one trigger? Can you Join 2 tables in a trigger? Below is my trigger, and then I wanted to add the bottom to it, but it doesn't work.
CREATE TRIGGER [mas_trigger] ON [dbo].[AccountBase]
FOR INSERT
AS
insert dbo.AR1_CustomerMaster
(Division, CustomerNumber,CustomerName,TermsCode, SalesPersonCode,
EmailAddress,URLAddress,PhoneNumber,FaxNumber,CreditLimit, ContactCode)
select
Case
when CFPDivision = 2 then '00' when CFPDivision = 3 then '10' when CFPDivision = 4 then '20'
when CFPDivision = 5 then '30' when CFPDivision = 6 then '40' when CFPDivision = 7 then '50'
When CFPDivision = 8 then '60' when CFPDivision = 9 then '70' when CFPDivision = 10 then '80'
when CFPDivision = 11 then '90'
end,
AccountNumber,[Name],
case
when PaymentTermsCode = 5 then '00' when PaymentTermsCode = 6 then '01'
when PaymentTermsCode = 7 then '02' when PaymentTermsCode = 8 then '03'
when PaymentTermsCode = 9 then '04' when PaymentTermsCode = 10 then '10'
when PaymentTermsCode = 11 then '15' when PaymentTermsCode = 12 then '20'
when PaymentTermsCode = 13 then '25' when PaymentTermsCode = 14 then '30'
when PaymentTermsCode = 15 then '98' when PaymentTermsCode = 16 then '99'
end,
CFSMAS200Salesperson,EMailAddress1,WebSiteURL,Telephone1,Fax,CreditLimit,CFSMASContactCode
from inserted
insert dbo.CustomerAddressBase
(CFSMASCustNum)
select
AccountNumber
from inserted
Join dbo.CustomerAddressBase
This is where it is failing.. Any Help?
FOR INSERT
AS
select
Case
end,
case
end,
from inserted
(CFSMASCustNum)
select
AccountNumber
from inserted
RE: Trigger not working with Join?
select
AccountNumber
from inserted
on inserted.<key field>=dbo.CustomerAddress.<key field>
HTH
