EMI problem affecting RF signals
I were facing problem from DC motor which is open
in the system,above the motor RF cable is running,
so,due to EMI problem its affecting RF signals.
Now i planned to cover EMI shield over motor,so it may avoid problem sffecting RF signals
& i used Stainless steel,still the problem is not solving
problem is i cant provide more thickness of stainless steel
bz of space problem.
any formulas to find out exact size of emi shield
& how can i get details of creating flux density
thanx in before
John
thanx in before
John
RE: EMI problem affecting RF signals
Air is a very good "shield" for magnetic fields in the sense that a bigger air gap reduces the field very quickly. Move the RF cables as far away as possible.
For high frequency shielding (>100kHz) you could put the RF cables in a seamless copper tube (as used in central heating systems. These make very good shields due to their high conductivity.
You won’t find usable equations to handle this sort of practical problem.
You can try just re-routing the existing cable, and see if a different orientation makes a difference. Especially try routing it at right angles to how it runs now.
Also, if the pickup is low frequency and the cable carries RF energy, you can simply buy a bandpass or highpass filter to place at the destination. The filter will let the RF through, but bounce back any low frequency EMI.
I would buy some of this thick foil and position it between the cable and motor, partially enclosing the motor (as much as possible without causing the motor to overheat).
