WELD WIRE QUANTITY CALCULATION??
We have to weld (build up) using open arc process on rollers with approximate dia of 45". Can someone please tell me how to calculate the quantity of weld wire required to build up approximately 15mm multiple pass using flux cored weld wire, size: 2.8mm. Thanks in advance.
RE: WELD WIRE QUANTITY CALCULATION??
Welding Assistant Software
www.geocities.com/pipewelder_1999
Further details on welding technology www.gowelding.com
