"Adding a "+", "-" circu to representing draft"
Dear All,
Is it possible to add a "+" and "-" circumscribed by a circle to represent a dimension for a feature ,that have a positive/negative draft of 1 degree it will be good especially for plastic parts.Because for plastic part for every will have a draft.So by adding that symbol for particular dimension, users will understood that from that point from that value the feature have a draft/taper".
If any body knows are how u r represnting in such type of situations please let me know
Reswam
RE: "Adding a "+", "-" circu to representing draft"
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
May be it has not existed in drafting standards,for convenience for that plastic parts how can we represent?
Reswam
Chris
ctopher's home site
If we make that symbol as block,it will not have associativity with that dimension,means whenever I move that dimension the block should also move then it will be gooD or is there any other way to convey the same meaning to represent that "from that point for that feature will have a draft"
Reswam
