Negative Jacobian error message on Modal Analysis
Every time I attempt to run a modal analysis on my model I get the error message:
* * * E R R O R * * * (WHILE RUNNING ANALYSIS)
NEGATIVE JACOBIAN ENCOUNTERED,
CHECK ELEMENT CONNECTIVITY AND JOINT COORDINATES FOR ELEMENT 21491
I have checked and this element has 8 points all of which are correct and shared with the appropriate amount of other nodes. Additionally the volume is positive for the element so that cannot be the problem. Anyone had this error before or have any ideas of what I can do to fix it?
Thanks in advance
Thanks in advance
RE: Negative Jacobian error message on Modal Analysis
