What is the rule for numbering an area in ANSYS?
For example,what is the number of every area in this part of program?
regards
Jili
! *                 solid model                  *
RECTNG,0,100,0,70,
CYL4,50,35,5
ASBA,       1,       2
RECTNG,20-.5,20+.5,70,100,
RECTNG,30-.5,30+.5,70,100,
RECTNG,40-.5,40+.5,70,100,
RECTNG,20-.5,40+.5,100,102,
RECTNG,20-1,20+1,70-1.5,70,
ASBA,       3,       6
RECTNG,30-1,30+1,70-1.5,70,
ASBA,       7,       6
RECTNG,40-1,40+1,70-1.5,70,
ASBA,       8,       7
RECTNG,40-1.5,40+1.5,70-3,70-1.5,
ASBA,       9,       8
RECTNG,30-1.5,30+1.5,70-3,70-1.5,
ASBA,      10,       9
RECTNG,20-1.5,20+1.5,70-3,70-1.5,
ASBA,      11,      10
RE: What is the rule for numbering an area in ANSYS?
The numbering rules are subject to change at each release -- and thus are undocumented.  Scripts that work in 7.0 wont' necessarily work in 9.0.
If you need to do selections, it is better to refer/select by locations.  More rigorous is the ability to query the last created entity...
If it seems like its a big pain to do and keep track of, then you're probably on the right track!
Good luck.
Rod
Dear Rod,
Thanks a lot for your answer.
Jili
