Heavy crude oil processing offshore FPSO
Offshore crude oil processing. Does anyone have any actual operating experience good or bad of installing a heat exchanger at the front end of the crude stabilisation process, basically heating oil/produced water and associated gas (upstream of the primary separator/slug catcher).
RE: Heavy crude oil processing offshore FPSO
Why are you wanting to heat the fluids? Is your question about heat exchangers upstream of the separator generally, of about the specifics of putting one on a floating production host?
