Soils Laboratory Manual
Can anyone recommend a good, comprehensive manual that covers step by step procedures for soil laboratory testing?  I am looking for something that is based on ASTM procedures, but is written in normal english.
Thanks in advance!
RE: Soils Laboratory Manual
This bool rules, well IMO, at any rate.
Soil Properties Testing, Measurement, and Evaluation
ISBN:0130930059
Liu, Cheng/ Evett, Jack B.
Binding:Paper Your Price: $73.00 GA Tech Engineers Book Store
Preface  v
Preface to the First Edition  vii
 Introduction
  1 (4)
 Description and Identification of Soils (Visual-Manual Procedure)
  5 (18)
 Determining the Moisture Content of Soil (Conventional Oven Method)
  23 (12)
 Determining the Moisture Content of Soil (Microwave Oven Method)
  35 (6)
 Determining the Specific Gravity of Soil
  41 (16)
 Determining the Liquid Limit of Soil
  57 (20)
 Determining the Plastic Limit and Plasticity Index of Soil
  77 (12)
 Determining the Shrinkage Limit of Soil
  89 (14)
 Grain-Size Analysis of Soil (Including Both Mechanical and Hydrometer Analyses)
  103 (28)
 Classification of Soils for Engineering Purposes
  131 (20)
 Determining Moisture-Unit Weight Relations of Soil (Compaction Test)
  151 (24)
 Determining the Moisture Content of Soil (Calcium Carbide Gas Moisture Tester)
  175 (8)
 Determining the Density and Unit Weight of Soil in Place by the Sand-Cone Method
  183 (20)
 Determining the Density and Unit Weight of Soil in Place by the Rubber-Balloon Method
  203 (14)
 Determining the Density and Unit Weight of Soil in Place by Nuclear Methods
  217 (16)
 Percolation Test
  233 (8)
 Permeability Test for Granular Soils (Constant-Head Method)
  241 (20)
 Permeability Test for Fine-Grained and Granular Soils (Falling-Head Method)
  261 (14)
 Consolidation Test
  275 (36)
 Determining the Unconfined Compressive Strength of Cohesive Soil
  311 (16)
 Triaxial Compression Test
  327 (34)
 Direct Shear Test
  361 (22)
 California Bearing Ratio Test
  383 (28)
Graph Papers  411 (12)
CD Installation Tips Soil Properties (5th Edition)  423
SCET - Techmaximus
