Custom Properties
Custom Properties
How do I make SolidWorks 2005 fill in my custom properties in my (.sldprt)(.sldasm)(.slddrw). Sometimes all I need to do is add a couple extra properties depending on what I'm doing for a particular customer, in my templates and formats I already have a few proporties set inside both of these files. I was kinda hoping that someone can guide me into a quick method so all I have to do is push a button and define the macro which a few keystokes and SW would fill in my new properties names and place "-" in value column. Can anyone help ?
Printed Circuit Board Designer
Salt Lake City, Utah
No Substitute for american muscle !
RE: Custom Properties
You can set-up seperate templates that define a particular material that you are going to use and then have the particular fields filled out in the template. Then each time you use that template the fields will always be the same, and fill out the remaining fields by keying them in.
There are many custom property macros that are free on the internet that can be easily customized for your particular needs. I recommend starting here for macros ht
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP1.1
I would not recommend using templates to control material notes in a drawing or any other information that changes from one drawing to another. Reason - because every time your template changes you have to change several templates. For example we changed our company name 3 times since starting SolidWorks. The next time we changed the text size for notes.
Bradley
Best Regards,
Jon
Thank-you jon for the website. The material propeties was exactly what I was looking for.
You could also use swCP3... available FREE at
http://www.swCP3.com
With Regards,
-mvk
Vinodh Kumar M.
www.swCP3.com
