partition
partition
partition
just like in abaqus is there a partitioning technique available in NE Nastran?
RE: partition
Can you expand on partitioning technique.  Please explain further.
RE: partition
partioning is diving a solid model into simpler and smaller regions to facilitate meshing. I figured out its called slice solid in nastran..
RE: partition
I'm assuming that you are using FEMAP with NE:
Use the geometry > solid > slice match to section into parts, then mesh with linked surfaces.
www.probasci.com -
Implantable FEA for medical device manufacturers
