Cannot get toolbar
Cannot get toolbar
Cannot get toolbar
I downloaded the MS Project add-in "Visio WBS Chart Wizard" which is supposed to add a toolbar to MS Project 2002.  I downloaded and installed.  It is showing up in the control panel as an installed program but it is not showing as a selection under VIEWS - TOOLBARS.  It is also not showing under the organizer on the toolbars tab.  I have uninstalled and re-installed but still cannot get it to work.  Any ideas?  (I was able to install the "Compare Project Versions" add-in with no problem.)
