Copying a sketch from one file to another
Is it just me or does something odd happen to a .sec sketch when it's copied from one file to another?
I've tried copying a feature sketch from one file to another and on top of not being able to accurately position it it seems to change a few dimensions unintentionally. How do you copy feature sketches?
My problem involoves one feature from a previous part revision and I want to copy only that feature into the new part where many changes have been made.
Eholmes
RE: Copying a sketch from one file to another
Best Regards,
Heckler
Do you trust your intuition or go with the flow?
I have not come up with a solution but maybe if you use WF2 you can copy the sketch as a feature instead of using the .sec file.
