Capturing sys reg profile settings
Is there a way to capture the system registry profile settings? What we are up against is if someone logs into a different computer, they lose all their settings since its on the other machine.
Thanks in advance
RE: Capturing sys reg profile settings
THe AutoCAD profiles are actually registry updates. To use your profile on another computer, you can export it and then import elsewhere.
"Everybody is ignorant, only on different subjects." — Will Rogers
