cad 2k5 printers
cad 2k5 printers
cad 2k5 printers
hey im lookin for some help
my lazerjet is broken so im using my dell 942 printer from home in the meanwhile.
my problem is that when ever i print my drawings on the dell the page comes out blank but if i import the file to adobe illustrator it prints fine.
if u can figure it out let me know
RE: cad 2k5 printers
First, does print preview show the print correct? If it does but is not printing what you see then try adding a new printer in the plot manager. Use a network plotter server if its on the network, else try a my computer setup and use a Hewlett Packard driver. Probably a deskjet (keep trying one till you find one you like). Good luck.
"Everybody is ignorant, only on different subjects." — Will Rogers
the print preview is blank and the printer is attached to the pc
The print preview should show you what you will get. Try printing by extents first and look at the preview. If that doen't get it, then try other ways (window, display, ...). Experiment and report back.
i got it to work after i reinstalled the printer
and it seems to only come out right if i use window
