Converting a Metric File to Standard
One of my students created his semester project in metric units, but our CNC software requires models to be in standard units.
I'm using NX2 on a PC. Any advice would be greatly appreciated!!
RE: Converting a Metric File to Standard
I live in Bulgaria (somewhere in Europe
Sorry if it's not appropriate joke.
But the converting of files inch<-->metric (that's what you're asking for, am I right?) is discussed in deep already. See this thread:
How to change units in a prt file
I hope this helped
_____________________________________
"...standards are great because they give nonconformists something to not conform to..."
_________________
Penkov, Peter I.
Non-standard Equipment Designer
The post processor will output which ever units you want either way.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I figured out a much easier way to convert files then what was posted.
On a PC, open the command window, change to the UGII directory, and type ug_convert_part -X Y. Replace X with "in" if you want to convert to inches or "mm" if you want to convert to mm. Replace Y with the path and file name that you want to convert. For example, to convert a file named "metric.prt" located in a folder called UG_Files to inches, type:
ug_convert_part -in c:\UG_Files\metric.prt
Likewise, if you wanted to convert that file from inches back to mm, type:
ug_convert_part -mm c:\UG_Files\metric.prt
No programs to download and a quick conversion. Thanks again for your help!
working with command window was discussed in the thread above. and ewh received a star for his detailed explanation.
_________________
Penkov, Peter I.
I'm always amazed how few nc programmers use assy mode. It's way easier and cleaner.
Bill
kukelyk
