Representation of Thru threaded hole in drawing
Dear All
I would like to represent a Thru threaded hole in drawing.
At present in drawing for thru threaded hole it is showing text "THRU ALL".I would like to keep a ISO symbol insted of text to eliminate text in drawing view.
If anybody knows how u r representing the same.Please let me know
Thanking you
Reswam
Thanking you
Reswam
RE: Representation of Thru threaded hole in drawing
As for using a symbol SW must have that symbol available to use it. If you select a Callout in a drawing you get and option in the property manager called "Variables". Select that and you will see a list of available symbols you can place in a Callout. Place that symbol callout in the place(s) you want it to show up in your calloutformat.txt file.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Thank you for ur info.I will try
Reswam
I understood that we have to edit that text file and we have to send that also who also use,then oly it will work am I correct?If any method like not sending again that libray/text file it may be good
Reswam
But if you need others to use the same file calloutfile then you will need to copy to each station or move the file to the server and change the file location under yout Tool\Options.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I do not think you need to send the calloutformat.txt file with the file for someone to read.
