Design Tables
Design Tables
Design Tables
When you have a design table open in a seperate window would it be possible to rename one of columns or just add some sort of remark letting the whole world that this column dimension is Dim A, this column is Dim H and etc.
Printed Circuit Board Designer
Salt Lake City, Utah
No Substitute for american muscle !
RE: Design Tables
Yup, you can do all that.  But you need to follow the rules.  Use the Help to find all that.  You'll love em once you get started.  Quick trick.  Name all the dimensions you want to have in the design table, then use the auto-create, you wouldn't believe how we used to have to do it!!  Ahh, the ole days.
John
RE: Design Tables
Thanks SolidsMaster, worked well ! I'll drink a pint for you .
RE: Design Tables
no problem, Design tables will grow on you...then you'll go someplace else and they say "design table? what's that"  I find it amazing how little it's used in certain places.  Let's start a revolution!!!
J
RE: Design Tables
You can do lots of Auotmation with a Design table. Take some Excel classes. I took level 3 excel and VBA programming. It well worth my time to take those courses. Some of the results of DT and Excel.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
RE: Design Tables
I have automated our Drawing templates to work with a DLL (VBA)
I am currently working on a customized Revision Block Version 2.0 the first version worked exactly how our old title blocks worked and was fully automated using my customized form.
Second version will use the solidworks built in rev table but will only be used as a hidden data base within the drawing.
The data needed off the table will be displayed elswhere on the title block itself. I am looking for VB Code samples on retrieving and setting the Rev Table data using my customized form.  Can anyone help me?
