Ordinate dimensions
Ordinate dimensions
All,
I have a sketch on a part where I dimensioned points with ordinate dimensions. I had to go back and add another point, but when I want to add the dimension to that point, I do not get the option. The help menu says:
To modify ordinate dimensions:
You can modify ordinate dimensions using commands on the shortcut menu. Right-click an ordinate dimension, select Display Options, then choose from these options:
Align Ordinate. Aligns all the dimensions along the ordinate with the 0.0 ordinate.
Add to Ordinate. Adds more dimensions later, along the same ordinate.
When I right click on any of the dimensions I do not get the option under "Display Options" to add anything. Any ideas??? I am running SW2004 SP3.0
Brad
Brad
RE: Ordinate dimensions
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Jason Capriotti
Smith & Nephew, Inc.
Check out the FAQ section on SolidWorks Installation
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
