Authorized Inspector For Pressure Vessels
I would like to locate an AI that is highly familiar with section VIII code, and the relevant calculations.
In particular modification of pressure vessel shell openings. I am increasing the diameter from 14" to 20" on one of the openings- what should I consider?
I have done some preliminary calculations using UG-37 through UG 43 of ASME Section VIII, but would like to have the calculations validated by an AI. This is my first time doing this type of calculation, so I would like to have it reviewed.
John
John
RE: Authorized Inspector For Pressure Vessels
The insurance AI can offer guidance into the process of notifying the local jurisdiction and verifying the credentials of the contractor.
Good luck.
