reference book on refrigeration
dear all,
i have been using and designing the shell & tube heat exchangers using the book of d q kern. process heat transfer
can anyone suggest a book for designing tube & fin type of heat exchangers used in the air conditioning and refrigeration industry.
thanks in advance
thanks in advance
RE: reference book on refrigeration
http:/
http://www.heatcraft.com/resources/software.asp
I am not sure if this is what you need, however I would first recommend referring to the "ASHRAE Handbook Refrigeration":
http://www.ashrae.org/.
Additionally, I often refer to the "Trane Air Conditioning Manual": http://www
The glass is neither half full nor half empty; it is simply twice as large as it need be.
