Roark's formula for square plate
Can someone has the Roark's Formula( or link) to find the stresses in square steel plate, supported on four corners with or without hole in the center.
RE: Roark's formula for square plate
http://www.roarksformulas.com/rytutor.html
http://www.welding-advisers.com/
http://www.roarksformulas.com/rytutor.html for that link I need to have that software or book. I knew that but I don't want to spent the money as I might not be using it again.
So any free link or access to the formula.
prex
http://www.xcalcs.com
Online tools for structural design
As well as the plate formulas, you need definition of constants, definition of edge conditions, etc., which are also given in the book.
If you go to "Google" and type in "roark's formulas", and select the second link that will give you Roark's book.
Everybody questions the price of getting a design right. As a professional, BMDesign, work out the cost for getting it wrong! Roark is probably one of the best engineering references going, Mark would be the other.
I echo the sentiment here, make the investment.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Sorry, I cannot find your model case in my Roark (6th ed.), if you mean what you say: square plate with hole supported on the four corners.
As alternatives you could:
1. redesign your part, support, and load so that it fits a case in Roark, then buy the book approx. $60 US used.
-or-
2. find a sharp modeler over on the Solidworks products forum that runs COSMOS, and give him the some of the $60 or a few rounds of Sam Adams to run your model.
Cheers
Greg Locock
That is an interesting question. Just guessing, but there are some comments in the Roark 6th Ed Sec.10.10 itself that might be the answer:
1. "No general expression for deflection as a function of position in a plate is given since solutions for plates with straight boundaries are generally obtained numerically ...", or
2. "It is impractical to include plates of all possible shapes and loadings, ...", and "There are many numerical techniques used to solve plate problems...".
Or, if this is a trick question, it may have something to do with Thread404-118635 and WHY manhole covers are round.
I'm pretty sure the answer is numerically unpleasant.
Cheers
Greg Locock
