torsional spring in ABAQUS
Is there anybody who could give me an example on how to define a torsional stiffness between two nodes in ABAQUS/Explicit?
Apparently this is not possible with SPRING elements, and requires the use of Connectors instead. However I can't find a suitable definition for type and behavior of simple torsional stiffness in one of the global directions (6).
The following is a section of the model data in my input file. I first define node 6000000, then connect it to the existing node 1000000 using the connector element 5000000, with torsional stiffness of 5500 N/m in direction 6 (rotation about Z). The program is complaining that orientations are missing for the connector, which surprises me because the stiffness is defined along a global direction
Thank you for your help
** DEFINE CONNECTOR
*NODE,NSET=SHAFTEND
6000000,19.3E-3,18.22E-3,100E-3
*ELEMENT, TYPE=CONN3D2, ELSET=SH1
5000000,6000000,1000000
*CONNECTOR SECTION, ELSET=SH1, BEHAVIOR=BEH1
FLEXION-TORSION
*CONNECTOR BEHAVIOR, NAME=BEH1
*CONNECTOR ELASTICITY, COMPONENT=6
5500
RE: torsional spring in ABAQUS
It is your element type that's causing the problem. Flexion-torsion always requires an orientation (v6.4 Analysis Manual sect.17.1.6)
You could either try a different element type, or create a dummy coordinate system that's the same as the global one.
