Meshing Imported Geometry in CosmosWorks
When you import geometry such as iges files into CosmosWorks you cannot de-feature. Can anyone suggest a meshing tool to de-feature the imported geometry at the meshing stage?
RE: Meshing Imported Geometry in CosmosWorks
I have run across the problem of meshing imported parts in cosmos even if it is defeatured because of the intricate geometry. I tried several mesh sizes form coarse to fine but alas it doesn't seem to work. Please let me know if you come across similar problem and if you were able to solve it. Thanks
ahad
