Looking for rough blue prints of the George Washington Bridge.
I'm working on the feature film "X-men" and am in need of the dimensions of the George Washington Bridge to use for 3-D camera tracking. Any sugjestions on were I might find this info would be greatly appreciated. Thanks! Swen Gillberg
RE: Looking for rough blue prints of the George Washington Bridge.
George Washington bridge is 4760 ft long.
Detail can be found at http://www.panynj.gov/tbt/gwmain.HTM
Hope that this helps.
I am looking for a design of a truss bridge. The bridge I must design has to be made outof twenty-five popsicle sticks. 11"X4". any help woulld be great!!
aprilstar,
     Please reply by email to MJVanVoorhis@CS.com and I'll help you out.  I assume that you will try to maximize strength within the limits of your sticks.  We can look at several designs and pick the one that works best.
     Also, this question deserves a new thread to allow others to reply - be sure to re-post your question so this thread (Rough blueprints for G.Washington bridge) can continue.
The length between anchorages is 1451 m (4760 ft) and the length of the center span is 1067 m (3500 ft). At the center the bridge is 65 m (212 ft) above the river. The bridge has a width of 36 m (119 ft), of which 27 m (90 ft) is used for roadway. The upper level carries eight lanes of motor-vehicle traffic and two footways, and the lower roadway, completed in 1962, has six lanes for motor-vehicle traffic. The upper roadway is suspended from four steel cables, each 91 cm (36 in) in diameter and composed of 26,474 wires. The total weight of cable wire is 25,673 metric tons. The cables are carried by saddles on top of two 184-m- (604-ft-) high steel towers. The bridge is operated by the Port Authority of New York and New Jersey.
"George Washington Bridge," Microsoft(R) Encarta(R) 98 Encyclopedia. (c) 1993-1997 Microsoft Corporation. All rights reserved.
Also, data can be found at the floowing links:
http://www.civil.rice.edu/scripts/bridges/display/bridgepage.asp?bridge=georgewashington&opennew=2&images=1
http://www.inventionfactory.com/history/RHAbridg/
Good luck!  Reply by email to MJVanVoorhis@CS.com if you need any 3d models...
