How can i build single pahse 227 from 380 volte 3 pahse delta?
hi all
In our factory all load supply from star/delta transformer 3 phase 380 volte,(without neutral system)
we want to install new 227 volte single phase for lighting..
do we can uase 2 phase-phase ?
if we want to build 48 volt dc , it is possible to use this voltage?
tank you every one
f-kh
tank you every one
f-kh
RE: How can i build single pahse 227 from 380 volte 3 pahse delta?
For 48 VDC you will need to install rectifiers. Most 3-phase rectifiers do not need a neutral.
For a rectifier installation I would highly recommend using a drive isolation transformer if that is not already built into your rectifier set.
