upgrade to SW office
Hi, I installed SW 2005 a few weeks ago. I have updated to SP1.1
I just realised we actually own SW2005 with office and want to install that also.
-Can I just go and install over the top of the previous install to get office working?
-Or do I need to uninstall and re-install the complete package?
-Or something else ? (main concern is that the discs are SP0 and am currently running SP1.1 SW)
RE: upgrade to SW office
Garland
Garland E. Borowski, PE
anyway all i really need to know just now is: should i install office (or office pro) just over the top; OR do i need to uninstall the original solidworks first?
So you better check with your VAR to insure that is what you have and you will probably have to do a clean install to get working correctly with the change in Bundles.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
i *thought* it was just SW we purchased so i installed that. now i wanted to use edrawing pro. and was told i should have installed sw with office; as that is what they bought...
so your saying i HAVE to uninstall and re-install?
and whats this about professional office. i don't think it allows me to install that with our registration.
Our Reseller here is offering a free upgrade from SW Office to SW Office Professional before April 15. (because they are discontinuing the SolidWorks Office product).
But... as your installation is SP1.1 and your CD is probably SP0.0, I think you should rollback your installation to SP0.0 before modifying the installation.
Whell... it will probably mess your SW. So just do a clean install.
thank-you all for your input.
David.
The only difference is the Reg. code. You may need to re-register your serial numbers to get the new reg. codes to run Office.
It all works fine now, even though PhotoWorks came from my CDs. (Weird--I didn't expect it to work so easily.)
Don't bother trying that if your serial number doesn't cover PhotoWorks and other Office products--it won't work and it's wrong to do.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
Chris
ctopher's home site
