Simulation Velocity
Simulation Velocity
Simulation Velocity
Is it possible to adjust the velocity more than the simple sliders provided in the feature tree?  I have applied both a linear and a rotary motor and I would like to speed up the rotary more than available, and slow down the linear more than the slider allows, is this possible?  I'm trying to simulate a cutting tool, so I need a high "RPM" and a low feed rate.
mncad
RE: Simulation Velocity
I've come to conclude they have two speeds - Off and On
--All seriousness aside, I have had a little luck with the first marker for very slow, but all the rest seem to have no effect on changing playback speed. You may want to try saving the simulation as an AVI file and adjusting the playback speed on your media player for demonstration purposes. Just beware the Photoworks rendering option, it takes forever.
Anyone can be Captain in a calm sea.
