ERROR MASSAGE
ERROR MASSAGE
ERROR MASSAGE
Since SW 2005 SP 1.1
I get the massage "unexpected file" when I save some assembly or drawing.
I click ok, the file finish to save and closed.
Does anybody have an idea?
RE: ERROR MASSAGE
Are you trying to save a file that was opened from a CD or some other non-writable media?  You should probably post more information.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: ERROR MASSAGE
No all the files are on my hard drive or on the server, I just try to save them after working on them.
RE: ERROR MASSAGE
I have gotten this before. Possibly a network problem.
RE: ERROR MASSAGE
I have gotten the same error.  Hasn't happened enough to track it yet and find out what is causing it.
mncad
RE: ERROR MASSAGE
Check your graphic card (driver, hardware acceleration,...)
Good Luck
RE: ERROR MASSAGE
I used to see similar things when a default file format was set to "read only" such as is found on a burned CD.  Windows XP normally has enough sense to change that setting when copied to the hard drive from a CD--Windows 2000 sometimes does not, and this can cause strange errors of the sort you reported.
I'd recommend saving work on your local drive whenever possible, then updating the network when the modifications are complete.  Of course, not everyone can do this--depends what your work environment and needs are.
Jeff Mowry
RE: ERROR MASSAGE
Theo,
We work with a large library of parts that never change and are stored on the server as read only.  We have been doing this since SW2001Plus and not had this error.  It has only shown up since we went to SW2005 SP1.1.  It doesn't seem to affect anything, SW just ignores it and goes on, or at least that is my experience with it so far.
mncad
RE: ERROR MASSAGE
I get sometimes "unexpected file format" error, when I do a save for a large assembly. Apparently SolidWorks is not affected, continues and finishes it's task successfully. I've first seen this error message in SW2005. Never happened in SW2004 or previous.
RE: ERROR MASSAGE
By the way, is this a Windows pop-up warning or SolidWorks?  Maybe that's the issue.
Jeff Mowry
