File Collaboration feature
Is there any way to change the Write Access for a whole assembly without changing each indivdual part?
RE: File Collaboration feature
Assuming you don't have a PDM system, this would be a Windows function & it depends on your User & Group setup. The permissions can be set at the containing folder level. RMB the folder & select Sharing & Security. If you are not sure about the settings, research the Windows Help files before changing anything.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Goto "Option...">"System Options">"External Reference">, then enable "Open referenced documents with read-only access.
Alex
Have you checked out the Collaboration option (under System Options) in SW05? See the what's new for claification... it's worth while to investigate, because works extremly well.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
This works,
But then every assembly I open all the parts are read only.
SolidCreative ... Sorry, I'm confused by your answer ... are you trying to say that you have  the solution to your problem, or that you are still needing one?
By enabling "open referenced documents with read-only access",
If you have assembly open with write access, you can "make read only" to the assembly and parts within it with just the one comand. That is good.
However, the person trying to get write access has to get rights to the assembly and each part individualy.
Plus, every part in every assembly you open, opens as read only.
Autodesk inventor preforms the multi enviroment function very well.
