Three Phase Separator
I am sizing a 3 phase separator in a gas plant that receives cooled vapor and liquid hydrocarbon from the 1st stage of a compressor and also a sour water stream. The separator will then separate the hydrocarbon liquid, water, and vapor before sending the vapor to the second stage of the compressor directly.
My question is this: what is the reason for the rules of thumb behind using a L/D ratio between 3 and 4?
I am trying to size the drum to fit in an existing structure to avoid having to build a new one. The vapor load is high and is calling for a 7.5 ft diameter. This is required for the critical velocity and also some other factors (such as minimum distance between HLL and LLL). I am using a vertical and a horizontal demister pad to allow for a smaller drum.
The problem I have is that I have PLENTY of liquid holdup time and don't need a 22.5 ft long drum for this reason. I would still have plenty of liquid holdup with a 15 ft long drum.
Is the reason for L/D ratio rule of thumb to allow sufficent time for the liquid droplet to fall before the vapor leaves the drum? The drum will have two inlets feeding through slotted T distributor directed at the vessel heads. Does this help? Can I push to have a lower L/D ratio with some other controls or is there a different reason entirely for the rule of thumb?
Thanks in advance for your help!
RE: Three Phase Separator
Visit Thread124-10444.
Please note that vessel diameter may not less than diameter needed for separation. Bigger diameter is more conservative in term of vapor separation. The demister pad diameter will decide the minimal vessel diameter in your case (I assume you use vertical vessel). For horizontal vessel, other criteria are applied.
I wonder why you need a plenty of liquid holdup time ? It should not be a requirement for good separation.
This will be a horizontal vessel and the critical velocity has a lot to do with the sizing of the vessel but there are some other factors I am having to consider such as minimum distance between HLL and LLL (simply minimum distance b/t taps for control). Not using a vertical drum because company prefers horizontal drums for water/hydrocarbon liquid separation.
I don't NEED plenty of holdup time. I have more than enough. I would think that typically the length of the drum is what determines your hold-up time after you consider all the factors that determine your diameter. The problem I was having was that the length in this case was being determined by the minimum L/D ratio that I had set by default at 3. I was questioning this because I wanted to lower that to 2. Company does have a requirement for liquid hold-up because this is a compressor feed drum and needs to have sufficient hold-up should an upset occur so that it doesn't trip the compressor on high level.
I ended up going with the L/D ratio of 2 because space is limited in existing structure and any excess cost associated with drum is well worth not having to build another structure.
The old ROT to separate light hydrocarbons and water is to provide a cross-section for a cross-flow velocity of 1 mm/s for water settling through an hydrocarbon with a range of viscosities from liquid butane to diesel. For unusual services, one should carry out lab tests on settling rates.
Maybe you should consider a (3 pahse) vertical separator in your case?
Best regards
Morten
