How to run NX Nastran 3.0 interactively in I-DEAS 11?
Hi, I try to run NX Nastran 3.0 in I-deas 11m2 in an interactive mode (under I-deas' NX Nastran task). But when I have set the solve option for NX Nastran executive command and TextEdit command and then solve a model, it always shows on the solve monitor panel that:
Writing NX Nastran file...
NX Nastran file written successfully
Starting NX Nastran Solution...
WARNING: NX Nastran Execution Summary file (f04) not found
NX Nastran Solution may be incomplete
NX Nastran Solution completed
Beginning import of results file...
Results import completed
Then no any results were solved.
However, when I try to run NX Nastran 3.0 outside I-deas with the file exported by I-deas, it's ok. No any error message.
The NX Nastran 3.0 I am using is a standalone product, enterprise version (not desktop). No any problems with it when running independently. The I-deas I am running is I-deas 11 m2.
What's the problem?
Thank you very much!
What's the problem?
